| Product(s): | ProjectWise Explorer Client | ||
| Version(s): | 08.11.11.559 | ||
| Area: | Orchestration Framework | ||
| Subarea: | File Property Extraction | ||
| Original Author: | Molly Watts, Bentley Technical Support Group |
After upgrading from a previous version of ProjectWise Integration Server, new msg files are not showing the file property data (To, From, Subject, ...)
The data extracted from new messages are different, and the column names in the users view need to be updated in ProjectWise Explorer to display the information.
