| Product(s): | ProjectWise Server V8i | ||
| Version(s): | 08.11.05.37 | ||
| Area: | Orchestration FrameWork | ||
File Property Extraction not working
OF Logging showed
009-10-16 12:21:51,797 [JobMessage] ERROR AFP.FileProps.Extractor [(null)] - Failed to extract file properties from the document [] file: 5940
2009-10-16 12:21:51,485 [JobMessage] ERROR AFP.Ftr.TextExtractor [(null)] - Failed to delete file D:\pw_extract_tmp\7cc15a0b-4ad5-450a-9671-3e61f4a727ec.msg attempt 0
Exception information:
Description: The process cannot access the file 'D:\pw_extract_tmp\7cc15a0b-4ad5-450a-9671-3e61f4a727ec.msg' because it is being used by another process.
2009-10-16 12:15:52,405 [JobMessage] ERROR AFP.Ftr.TextExtractor [(null)] - Failed to delete file D:\pw_extract_tmp\7cc15a0b-4ad5-450a-9671-3e61f4a727ec.msg attempt 0
Application or Object Name: mscorlib
Method: WinIOError
Call Stack: at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.File.Delete(String path)
User was not able to delete message. Something had a lock on the .msg
The extraction folder has now been excluded from real time Antivirus scans and restarted MSMQ.
