| Product(s): | Project Administrator V8i | ||
| Version(s): | 08.11.05.37 | ||
| Area: | Orchestration Framework | ||
File Property Extraction
User is getting error when trying to run File Property Extraction
OrchestrationFramework Loggin:
2009-10-15 16:13:36,570 [1] ERROR OrchFwrk.Drainer [(null)] - Process on System.Messaging.MessageQueue failed to initailize.
The log file for database 'of' is full. Back up the transaction log for the database to free up some log space.'
User needed to back up OF database. Low on disk space on server and low memory.
Bentley's Technical Support Group requests that you please confine any comments you have on this Wiki entry to this "Comments or Corrections?" sectioXn. THANK YOU!
