| Product(s): | ProjectWise Integration Server | ||
| Version(s): | N/A | ||
| Area: | Orchestration Framework | ||
| Subarea: | Full Text Indexing | ||
| Original Author: | Molly Watts, Bentley Technical Support Group |
The CPU on the indexing server was occasionally at 100% because of the process dmsifilterhost.exe. Turns out it was hanging on processing Office documents due to the incorrect ifilter installed.
