| Version(s): | 08.11.09.845+ |
| Area: | Subsurface Utilities |
Question:
If you move a node, will the attached pipes move with the relocated structure?
Answer:
Yes, the attached pipes will maintain their connectivity and dynamically shift with the relocated structure.
