| Product(s): | ProjectWise V8 XM Edition | ||
| Version(s): | 08.09.04.89 | ||
| Area: | Orchestration Framework | ||
Full Text Search feature is not working after the initial pass.
1. Removed bad files. A few bad files in the system was sending MicroStation for a loop.
2. Increased the memory limit from 150MB to 250MB for the MicroStation process (MicroStation process was running short on memory).
The two issues were causing a backlog in processing so when good documents got to the front of the line, the wait had been too long.
