| Version(s): | 08.11.09.845+ |
| Area: | Subsurface Utilities |
Question:
Is the 100 inlets limitation per drainage library, or is it the total number of allowed inlets within StormCAD?
Answer:
You can have 100 inlets per model. You can create multiple drainage models that can be referenced together that each have up to 100 inlets without the need for an additional license.
