| Product(s): | ProjectWise V8i | ||
| Version(s): | 08.11.05.37 | ||
| Area: | Orchestration Framework | ||
Indexing and Extractions are not working. No errors in the log file and files are not going into the temp sync-extraction directory.
Uninstalled everything (Integration Server and OFW), deleted the database tables and recreated from scratch. It appears the database got corrupted.
Other notes:
Document processors are running on a different server than the integration server. Confirmed Message Queuing is installed on both servers. Ran the DMSAFPEngine -makeHead and -makeTail per the instructions and configured everything in the Orchestration Framework control panel.
