| Product(s): | ProjectWise Integration Server | ||
| Version(s): | 08.11.11.590 | ||
| Area: | Orchestration Framework | ||
| Subarea: | Full Text Indexing | ||
| Original Author: | Dana Guthrie, Bentley Technical Support Group |
Outlook Msg Files are not full text indexing on Server 2012
I have installed Orchestration Framework and the Integration server on a 2012 r1 server, and I have also installed the required msg ifilter as directed in the implementation guide. I am able to get file properties from message files but not full text indexing.
Microsoft does not support the 32 bit msg ifilter on a 64-bit operating system running windows search. The msg ifilter we refer to in the implementation guide is the 32 bit version. Since Microsoft server 2012 r1 is a 64-bit operating system, the 32 bit msg ifilter listed in the implementation guide will not work. The same problem occurs on a Windows 8.x system if you install the 32 bit version of office, if you put a message file on the desktop and try to search the contents windows will not find it..
