| Product(s): | ProjectWise Integration Server | ||
| Version(s): | 08.11.11.123 | ||
| Area: | Orchestration Framework | ||
| Subarea: | Installation | ||
| Original Author: | Bill Kenney, Bentley Technical Support Group |
"Error 1923 service orchestration framework could not be installed, verify permissions for
system services"
The User used in the Orchestration Framework install was a "Local Admin"
on the Integration Server box (Windows Server 2008), and had log on as a
service rights. User had full access to the database. The error was apparently not a PW Error
Product: ProjectWise Server V8i
Version: 08.11.11.123
Area: Orchestration Framework, Problem ID#: 88172, Select Category
User tried toggling the short name instead of the domain name for the
Orchestration Framework Server, and the connection went through without
error. For some reason, the FQDN name didn't work.
