| Product(s): | ProjectWise Integration Server | ||
| Version(s): | 08.11.11.574 | ||
| Environment: | Windows Server 2008 R2 | ||
| Area: | Orchestration Framework | ||
| Subarea: | Installation | ||
| Original Author: | Jacquelene Smiro, Bentley Technical Support Group |
When logged into ProjectWise Orchestration Admin on head server it shows that failure of node dispatch processors on tail server. If logged into the tail server, it shows node failure on head server. It appears that each server is working however, it seems as if there is some type of communication failure between the two servers. They are both on the same domain.
