| Product(s): | ProjectWise V8 XM Edition | ||
| Version(s): | 08.09.04.89 | ||
| Area: | Orchestration Framework | ||
"javaw.exe failed to start" and it references Orchestration Framework
Every time we reboot our server we get this error in the event viewer "javaw.exe failed to start" and it references Orchestration Framework.
All the OF processors appear to be working and we do not see any other errors. should we be concerned about this error?
The "javaw.exe” is a command line utility delivered with Java.
According to development it is used for the Bentley Logger. So it should not be causing any issues with the OF running its normal processes. However if you need to run the logging you may need to reinstall Java on this system.
Bentley's Technical Support Group requests that you please confine any comments you have on this Wiki entry to this "Comments or Corrections?" sectioXn. THANK YOU!
