| Product(s): | ProjectWise Server V8i | ||
| Version(s): | 08.11.09.122 | ||
| Area: | Orchestration Framework | ||
OF admin is showing all red X's for all document processors.
If the user restarts the Orchestration Framework service, it gives a message that there is no work and shuts down.
User indicated that the database users password had changed
Had user run ..program files (86)\bentley\projectwise\Orchestration\dbsetup.exe and re-enter the password for the user and made sure the connection was made, then restarted the OF service and it all started working again.
User had a head tail setup which means she had to run the dbsetup tool on both machines to reconnect to the OF database.
