| Product(s): | InRoads |
| Version(s): | 08.11.07+ |
| Area: | Geometry |
Question:
How can cogo points be created with the same point name as the horizontal alignment points?
Answer:
First go to Geometry>Horizontal Curve Set>Events. The "Alignment Point to Cogo" option will adds the event points as cogo alignment points.
Next use the command, Geometry>Utilities>Assign Names. Make sure the "Check for Coincident Points" option is toggled on.
Point names will then match in the alignment and in the cogo buffer.
