| Product(s): | ProjectWise Server V8i | ||
| Version(s): | 08.11.07.133 | ||
| Area: | Orchestration Framework | ||
When configuring Orchestration Framework to connect to a SQL Express instance that is on a separate server, dbsetup gives a connection error
The database server had Windows Firewall turned on. We added a program exception for SQL Express, but then had to restart the SQL service and the Firewall for OF to connect to the database
