| Product(s): | ProjectWise Server V8i | ||
| Version(s): | 08.11.09.122 | ||
| Area: | Orchestration Framework | ||
Orchestration Framework service will not start. Running repair on Integration server will get so far and roll back with error 1722 given. After integration server fails and rolls back check even viewer and you’ll notice an error stating “implantation is not part of the Windows Platform FIPS validate cryptographic algorithms. "
Have user either disable FIPS or have them upgrade to SS4 which is now FIPS compliant.
