| Version(s): | 08.11.09.845+ |
| Area: | Subsurface Utilities |
Question:
Where are Scenarios stored?
Answer:
Scenarios are stored in Utility Project in the DGN file. The DGN files are therefore portable without needing to package additional files other than DGN references. For organizations who want a set of prebuilt scenarios available for their projects at startup you can configure scenarios in the DGN library which contains your hydraulic seed file.
See: communities.bentley.com/.../24538.hydraulic-seed-file
