| Product(s): | ProjectWise Integration Server | ||
| Version(s): | 08.11.11.111 | ||
| Area: | ProjectWise Administrator | ||
| Subarea: | Administrative Tools | ||
| Original Author: | Molly Watts, Bentley Technical Support Group |
Error 58209 Can not create document Cannot format data string: non-negative integer number is required
The environment was configured with a document code, with a placeholder attribute. The attribute used as the placeholder was configured with a format string that did not comply with the data that was being entered (%3u is expecting an integer)
In the attribute settings, modify the format string to comply with the data that will be entered into the attribute or remove the format string all together.
