| Product(s): | ProjectWise Integration Server | ||
| Version(s): | 08.11.11.559 | ||
| Area: | ProjectWise Administrator | ||
| Subarea: | Administrative Tools | ||
| Original Author: | Jacquelene Smiro, Bentley Technical Support Group |
Error: Not able to modify the global integration server properties on the server because of the following error: Datasource description was not found in the server configuration file.
When attempting to create new datasource in ProjectWise user receives error.
1. In this case DBpassword= in dbo section was listed before DBuserName. Reversed order so that DBuserName was first in order.
