| Product(s): | ProjectWise Integration Server | ||
| Version(s): | 08.11.11.566 | ||
| Area: | ProjectWise Administrator | ||
| Subarea: | Environments | ||
| Original Author: | Molly Watts, Bentley Technical Support Group |
"Failed to delete the interface. The interface is used, so it cannot be deleted."
There are attributes configured in an attribute layout for that interface
In ProjectWise Administrator, expand Environments
Under each enviornment, expand Attribute Layout
For the interface you are trying to delete, click on 'Attributes' tab and 'More Attributes' tab
