| Product(s): | ProjectWise Integration Server | ||
| Version(s): | 08.11.11.574 | ||
| Area: | ProjectWise Administrator | ||
| Subarea: | Environments | ||
| Original Author: | Molly Watts, Bentley Technical Support Group |
Failed to update document code structure.
New code definitions can not be saved because some required fields are empty.
When attempting to add or change document code on an existing environment, however there are existing documents in the environment without values for the attributes contained in the document code.
Undo the changes made in the "define document code" wizard
Search ProjectWise Explorer for all files in the environment (be sure to select "find in this environment only")
Add columns to your view for each of the attributes
Select the documents from the search results that don't have values for the attributes
Right click-modify
Select the Environment tab and enter a value for the attributes (will change for all selected, so may need to do in smaller groups, depending on what the value needs to be)
Back in ProjectWise Administrator, make the desired changes to the document code, and the wizard should finish without error
