| Product(s): | OpenRoads Navigator Mobile App |
| Version(s): | 05.04.01+ |
| Area: | General |
Question:
Can you locate a point using GPS in the field?
Answer:
Yes, if GPS is available, you can use the Follow Me tool. This tool will allow you to see a small circle on the screen that represents your current location. As you change location, this circle will move with you. Note: The accuracy depends on the type of mobile device and cellular connections.
