| Variable | Description |
| $DATETIME$ | Current date and time |
| $DATE$ | Current date |
| $Time$ | Current time (24 hour format) |
| $ENV$ | Environment number |
| $ENV.NAME$ | Environment name |
| $ENV.DESCR$ | Environemnt Description |
| $ENV.TABLENAME$ | Environment attribute table name |
| $ENV.ATTR$ | Environment attriubte Record number |
| $ENV.PARAM$ | Environement Flags |
| $INTERFACE$ | Interface number |
| $INTERFACE.NAME$ | Interface name |
| $USER$ | Current user number |
| $USER.NAME$ | Current user name |
| $USER.DESCR$ | Current user description |
| $VAULT$ | Folder number |
| $VAULT.NAME$ | Folder name |
| $VAULT.DESCR$ | Folder description |
| $VAULT.FULLNAME$ | Folder name |
| $VAULT.FULLDESCR$ | Folder Description |
| $DOCUMENT$ | Document number |
| $DOCUMENT.FULLNAME$ | Full Document name |
| $DOCUMENT.FULLDESCR$ | Full document name (Path Contstructed from descriptions) |
| $VAULT.CODE$ | Folder Code |
| $VAULT.TYPE$ | Folder type |
| $VUALT.STORAGE$ | Folder storage number |
| $VAULT.STORAGE.NAME$ | Folder storage name |
| $VAULT.WORKFLOW$ | Folder workflow number |
| $VAULT.WORKFLOW.NAME$ | Folder workflow name |
| $VAULT.STATE$ | Folder state number |
| $VAULT.STATE.NAME$ | Folder state name |
| $VAULT.MANAGER$ | Folder manager number |
| $VAULT.MANAGER.NAME$ | Folder manager name |
| $VAULT.CREATOR$ | folder creater number |
| $VAULT.CREATOR.NAME$ | Folder creator name |
| $VAULT.CREATETIME$ | Folder create time |
| $VAULT.UPDATER$ | Folder updater number |
| $VAULT.UPDATER.NAME$ | Folder updater name |
| $VAULT.UPDATETIME$ | Folder update time |
| $VAULT.SUBPROJ$ | Y if folder has subfolders, "N" - otherwise |
| $EDIT# | Value from edit field specified by colum name |
