| Version(s): | 08.11.09+ |
| Area: | Civil Cells |
Question:
Can you change the civil geometry stationing in a civil cell to match the direction of the corridor stationing?
Answer:
Currently this is not allowed. In placing the civil cell, the geometry is potentially reversed. Therefore, all reporting should be off the main alignment.
