| Product(s): | InRoads |
| Version(s): | 08.11.07+ |
| Area: | Survey |
This wiki will demonstrate how to add a new *.tiw to the Import Survey Data “Files of Type” dropdown menu.
- Save the new survey *.tiw file in the same program directory as the existing *.tiw files. The default location is C:\Program Files (x86)\Bentley\InRoads Group V8.11\Data.
- From within InRoads, go to File > Import > Survey Data. Set Files of Type to “Text File(*.*)” and Template to “Text File”. Place the cursor in the File Name field, and browse to select the raw data file to be imported.
- Click Import and this will bring up the Text Import Wizard.
- Click Open and select the new tiw file.
- Click Open to load the tiw.
- On the Text Import Wizard dialog, click Save As which will overwrite the tiw file. Click Yes when prompted to Confirm Save As.
- This will bring up a dialog to Save Format to File Types. Click Yes.
- Cancel out of the Text Import Wizard.
- Go to File > Import > Survey Data and note that the new tiw is listed in the Files of Type pulldown.
