| Product(s): | ProjectWise Integration Server | ||
| Version(s): | 08.11.09.122 | ||
| Area: | ProjectWise Administrator | ||
| Subarea: | MISC | ||
| Original Author: | Dana Guthrie, Bentley Technical Support Group |
User is in the Projectwise administrator looking at document processors \ File Properties \ Property sets and there are two property sets that have strange names. Example: ISebiesnrMkudrfcoIaamtykdDa
In ProjectWise Explorer under the file properties of a file, one of the strange names appears.
Can the property and or property set be deleted, hidden or renamed so it looks more informational.
(if running) Projectwise Document processor \ File properties will extract any file property it finds. If a name is not provided for the property set or file property from with in the file, then Projectwise will create the "strange name". You can change the name because Projectwise tracks the file property sets and file properties via an assigned GUID.
You cannot delete the properties and Property sets once they have a value set for a file.
In ProjectWise Administrator go to Document Processors \ File Property Extraction \ Property sets
Right click on the strange name and choose Properties.
Under Display name, rename to something more informational.
Click on the Property set to see the list of properties.
If they are something that you want to keep, then do nothing.
If the property needs to be renamed, simply double click and changed the display name for each property.
In PojectWise administrator go to Document Processors \ File Property Extraction \ Property sets
Double click each property and check the boxes for "Hidden" and "Do not extract". You will need to hide each property in a property set in order for it to not show in Projectwise Explorer.
For more information about File Properties, Search the Projectwise Administrator help for "Document Processors"
