| Product(s): | ProjectWise Integration Server | ||
| Version(s): | 08.11.11.559 | ||
| Area: | ProjectWise Administrator | ||
| Subarea: | MISC | ||
| Original Author: | Dana Guthrie, Bentley Technical Support Group |
The SQL server had an issue this morning and the connection was lost to the integration server. The connection issue has been resolved but now there is a Red X on the datasource listing icon in Projectwise Explorer and Admin. What can we do to remove the Red X
Stop and Restart the ProjectWise Integration service. If your Integration servers are setup in a cluster environment, then you will need to restart the service on all Integration servers in the cluster.
