| Product(s): | ProjectWise Integration Server | ||
| Version(s): | 08.11.11.574 | ||
| Area: | ProjectWise Automation Service | ||
| Subarea: | i-model Composition Service | ||
| Original Author: | Molly Watts, Bentley Technical Support Group |
When creating a rendition via ProjectWise Explorer (right click-create rendition) user was seeing inconsistencies with the resulting file's "created by" ProjectWise user. Sometimes would show the user currently logged into ProjectWise, but another project would show an administrator account
The Change datasource settings is used when the rendition is placed into a separate datasource than the source document, and in that case a username/password for that datasource is required. This can also be used when the users creating renditions do not have access to the destination folder, when working within the same datasource.
