| Product(s): | ProjectWise Server V8i | ||
| Version(s): | 08.11.09.122 | ||
| Area: | Automation Services | ||
| Original Author: | Molly Watts, Bentley Technical Support Group |
Running a Dynamic Composition Service job to publish i-model gets error: Failed - MSProcessor - imodelComposer has tried 4 times before exceeding it's maximum attempts at processing a job message
The problem was with the workspace that was configured to use. Either uncheck the "override ProjectWise workspace" option in the job to use what PW is configured to use for those files, or check it and point to a valid workspace on that server
