| Product(s): | ProjectWise Integration Server | ||
| Version(s): | 08.11.11.111 | ||
| Area: | User Synchronization Service | ||
| Original Author: | Philip Conard, Bentley Technical Support Group |
A user is getting error 58096 when logging into the datasource
Mapped error code: 58096
Login denied. Checking Windows NT user account failed.
There was also an error code in the logs of 1793.
Product: ProjectWise Administrator V8i
Version: 08.11.11.111
Area: User Sync Settings, Problem ID#: 92049, PROBLEMSOLVING
In AD the account was set to an expired date. Once it was corrected the
user was able to login
