| Version(s): | 08.11.09.845+ |
| Area: | Subsurface Utilities |
Questions:
I placed my node using the wrong surface. Can I change the reference to a different surface?
I placed a node using a reference surface. Can I remove the reference surface and use a fixed elevation?
Answer:
Yes, Select the node in question and watch the heads up prompts. See video below.
