| Product(s): | Bentley MXROAD | ||
| Version(s): | MXRoad V8i | ||
| Area: | Utilities | ||
| Subarea: | License Management Tool | ||
| Original Author: | Purva Lakde. Product Advantage Group |
Problem Description:
How to deactivate the application which is not required from License Management Tool.
For example: I would like to deactivate the product called “Rail Overhead Line”.
Workaround:
1. Go to Regedit > HKET_CURRENT_USER> Software > Bentley Licensing > 1.1, you will see the list of the applications which you have installed on your system.
2. Delete/Remove the application from the regedit, right click on 1608 as it refers to rail Overhead Line > Delete.
3. This will deactivate the product from the License Management Tool.
