Applies To | |||
Product(s): | OpenRoads | ||
Version(s): | 08.11.09 | ||
Environment: | |||
Area: | Survey | ||
Subarea: | |||
Original Author: |
Amita Shinde. Product Advantage Group |
Question :
How to import field book data that is NOT in a txt or csv format?
Answer:
The field book data in a ctl format or any other format other than .txt or csv can be drag -n-dropped in the "Survey" panel of "Project Explorer". For csv or txt, you will have to use the "Text Import Wizard". Right click on a new filed book "Load > File Using Text Import Wizard".
