Error 58273 Identity Mismatch error logging into ProjectWise
 Product(s):ProjectWise Design Integration
 Version(s):10.00.03.49
 Environment:N\A
 Area:N/A
 Subarea:N\A
Error or Warning Message
Error 58273 Cannot login to the datasource
Identity mismatch. Please contact your ProjectWise Administrator
Explanation
When logging into ProjectWise Explorer using Bentley IMS login, there is a mismatch between the PW account settings and the email account logged into the CONNECTION Client
How to Avoid
  1. In PW administrator, users section, browse to the user having the issue
  2. Open the users properties, Federated Identity tab
  3. Click disassociate
  4. Enter the users email address in the Identity name field and click apply (note this should match the email logged into the CONNECTION Client)
