| Version(s): | 08.11.09+ |
| Area: | Corridor Modeling |
Question:
Can you use target aliasing from Corridor A to B, and then at another location from B to A?
Answer:
No - that produces a recursive situation. As a work around, you can copy the geometry without rules or remove rules of the element. For more information regarding copying geometry, please refer to the link below:
communities.bentley.com/.../14152.how-do-i-create-a-copy-of-civil-geometry
