| Version(s): | 08.11.09+ |
| Area: | Terrain Model |
| Original Author: | Chris Key, Bentley Technical Support Group |
Question:
How do you delete a feature from a OpenRoads Terrain Model? This was accomplished using the Delete Feature command in the native InRoads explorer to remove a feature from a DTM, but is there an equivalent OpenRoads tool?
Answer:
The tool used for deleting a feature from a Terrain is the 'Remove Features' option located under the Terrain Model editing tools. This will allow you to select a terrain model and delete a feature which is part of the terrain. This will remove all types of features including Brea Lines, Voids, Holes, etc. Please view this video for a demonstration on the Remove Features tool.
Video: Remove Feature from Terrain Model
