Integration server running in 4 hour eval mode
Product Specific Licensing Landing Page
ProjectWise / Web Portal Licensing Landing Page
  Product(s): ProjectWise Integration Server
  Version(s): 08.11.11.111
  Area:  Integration / Caching /Gateway
  Subarea:  Licensing
  Original Author: Jacquelene Smiro, Bentley Technical Support Group
Problem ID#: 90894 - Integration server running in 4 hour eval mode
Problem:
Integration server running in 4 hour evaluation mode. Look to see if
there is anything under HKEY_Current User\SOFTWARE\Bentley\Lice
nsing\1.1\Applications
Product: ProjectWise Server V8i
Version: 08.11.11.111
Area: Application Svr - Integration Svr, Problem ID#: 90888, ERRORMESSA
The License Management Tool  was not run as the Admin so values written to the registry were written to the wrong registry key (hkeyCurrent User). The license needs to go under Hkey Local machine.
Delete the key one under Hkey_Current_User at licensing level, one above 1.1 HKEY_Current User \SOFTWARE\Bentley\Licensing\1.1\Applications - then but run license tool as admin  and go thru the activation wizard (or re-import the xml file if using a checked out license) .
It should write a new key to
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Bentley\Licensing\1.1\Applications\
1023 = caching
1016 = integration
