| Bentley Common Predefined (CSB) | Initializes the Managed Workspace | ||||
| Set Datasource Variable | Set Configuration Root Folder | ||||
| Common Predefined -Include Common_Predefined.cfg | Includes Initial .cfg File joining PW location to cfg files | ||||
| Common Variables | Sets Dynamic Work Area Variables | ||||
| Organization Customization -Include Common_Predefined_PWSetup.cfg | Allows an organization to augment the Common Predefined cfg | ||||
| Default Variables | Sets Default WorkSpace variables | ||||
| WorkArea Root: -Include Common_Predefined_FindWorkAreaRoot.cfg | Work Area Root must to be found to set base location for related configurations | ||||
| Determine PW Explorer Version: -Include Common_Predefined_PWExpVersionCheck.cfg | Checks Version of ProjectWise Explorer and allow for changes | ||||
| Determine Product Version: -Include Common_Predefined_ProductVersion.cfg | Allows detection of product version | ||||
| Include WorkArea Control: -Include WorkAreaPWSetup_Predefined*.cfg | Allows the setting of workspace information within a specific work area | ||||
| Define PW Drive Variables: -Include Common_Predefined_PWDrive.cfg | Allows detection and setting of ProjectWise Drive related variables | ||||
| Include Workspace Groups: -Include Common_Predefined_WorkspaceGroups.cfg | Allows for workspaces to be located in an alternated and grouped by "name" | ||||
| Workspace Groups PW Setup: -Include WorkSpaceGroupsPWSetup_Predefined*.cfg | Allows for variables to be defined for all workspaces in that "Groups" locations | ||||
| Workspace Groop PW Setup -Include WorkSpaceGroupPWSetup_Predefined*.cfg | Allows for variables to be defined for all workspaces in that "Group" locations | ||||
| V8 Variables | Section: V8 Related related variables | ||||
| Set V8 Framework Variables | Sets framework variables and verifies existence | ||||
| Include Configuration PW Setup -Include V8WorkspacesPWSetup_Predefined*.cfg | Allow for workspace specific V8 variables | ||||
| Include Workspace Setup -Include WorkspacePWSetup_Predefined*.cfg | Allow for workspace specific V8 variables | ||||
| CONNECT Edition Variables | Section: CONNECT Related related variables | ||||
| Set CONNECT Edition Framework Variables | Sets framework variables and verifies existence | ||||
| Include Configuration PW Setup -Include ConfigurationPWSetup_Predefined*.cfg | Allows for configuration specific CONNECT variable | ||||
| Include Workspace PWSetup -Include WorkspacePWSetup_Predefined*.cfg | Allows for workspace specific CONNECT variables | ||||
