| Product(s): | ProjectWise Explorer Client | ||
| Version(s): | 08.11.11.123 | ||
| Area: | Open / Save / Copy / Move | ||
| Original Author: | Molly Watts, Bentley Technical Support Group |
When using the Advanced Document Creation Wizard to create a new document, and selecting the option to "Use ProjectWise document as a template", when both files exist in the same ProjectWise environment, the exact values are copying over, when they would like the default values to be used
1. In the ProjectWise Administrator, browse to the environment and the specific attribute
2. In the properties of the attribute, General tab, check on the option to "Clear attribute value when: copied inside environment"
