| Product(s): | ProjectWise Explorer Client | ||
| Version(s): | 08.11.11.113 | ||
| Area: | Open / Save / Copy / Move | ||
| Original Author: | Bill Kenney, Bentley Technical Support Group |
User was getting "Error 55037 File not found on server"when trying to open a dgn in ProjectWise Explorer.
Product: ProjectWise Client V8i
Version: 08.11.07.133
Area: Explorer, Problem ID#: 84898, Select Category
Examined the storage server dms folder, the document showed as there but as 0 byte file. ProjectWise Explorer showed 150Kb or so.
Re-starting the service on the ProjectWiseCaching Service had no effect on the error. However, re-starting the ProjectWise Integration Server "Service" fixed the issue (or combination of both service re-starts)
