Cannot open file class not registered
Problem Description
Trying to open a V7 file.  When he selects the file, it checks the references and everything, and then gives an error that says "HR result=80040154.  Cannot open file--class not registered."
Enable legacy integration with MicroStation version J files in PW Administrator > Applications > MicroStation > Action tab > highlight version 7/Ustation J > Populate the radial button for Enable Legacy Integration
Product TechNotes and FAQs
External Links
Bentley LEARN Server
Comments or Corrections?
Bentley's Technical Support Group requests that you please confine any comments you have on this Wiki entry to this "Comments or Corrections?" sectioXn. THANK YOU!
