| Product(s): | ProjectWise Explorer Client | ||
| Version(s): | 08.11.11.574 | ||
| Area: | Open / Save / Copy / Move | ||
| Original Author: | Dana Guthrie, Bentley Technical Support Group |
User has an active file that has a document code, and the file also has versions.
User wants to move the active file to a different folder but not the versions. Is this possible?
No this is not possible. There is a datasource setting to allow documents with versions to be moved, but the Active files and version files must stay together.
In Projectwise Administrator, log in as the admin
Right click on the datasource and choose properties
Click on the Settings tab
Scroll down to the Version section.
Check on the settings: Document having versions can be moved
Projectwise Administrator Help \ Projectwise Administrator Reference \ Datasources \ Datasource Properties Dialog \ Datasource Properties Dialog - Settings Tab (Datasource Settings)
