| Product(s): | ProjectWise Explorer Client | ||
| Version(s): | 08.11.11.111 | ||
| Area: | Open / Save / Copy / Move | ||
| Original Author: | Bill Kenney, Bentley Technical Support Group |
User cannot delete file
Product: ProjectWise Client V8i
Version: 08.11.11.111
Area: Explorer, Problem ID#: 88608, Select Category
User had versions of the file that were not showing. Enable setting for
"Show all versions". File had a version that was set to "Final Status"
Change the Status to"Previous" via right click > Change State > Remove
Final Status. You can now delete the "active" version.
