| Product(s): | ProjectWise Explorer Client | ||
| Version(s): | 08.11.11.574 | ||
| Area: | Open / Save / Copy / Move | ||
| Original Author: | Dana Guthrie, Bentley Technical Support Group |
Last error [50000] Error copying out folder. Not found.
User right clicks on a folder and goes to properties, statistics and sees that there are 10 files in the folder. However when he highlights the folder he cannot see the files in the folder
User right clicks the folder and chooses ‘Copy Out’ to copy out the folder and files that the statistics tab indicates are there
User gets error message Last error [50000] Error copying out folder. Not found.
While the user has permissions to see the folder the user does not have permissions to the documents \ files in the folder.
Contact your ProjectWise Administrator to get permissions to the documents in the folder.
