Error on thread and file stuck with coming in status
User gets "Error on thread", possible corrupt file during file creation. File is stuck with "coming in" status.
User had the file with a "coming in" status. User went to Local Document Organizer and went to that User node - freed the document which changed the status to "checked in". This changed the status from "coming in" to "checked in", but it became a document without a filename. Then, right click on the document > Modify > Select arrow in the lower right corner >  Delete File
It then could be deleted by right on document, click > Delete
Product TechNotes and FAQs
External Links
Bentley LEARN Server
Comments or Corrections?
