| Product(s): | ProjectWise Explorer Client | ||
| Version(s): | 08.11.11.574 | ||
| Area: | GUI | ||
| Original Author: | Dana Guthrie, Bentley Technical Support Group |
We have many environments and Interfaces. When I navigate to a certain folder or project folder I would like a certain interface to be used.
There currently is not a way to assign an interface to a folder or project. However you can assign an interface as your personal default interface per datasource.
Launch ProjectWise Explore and log in
Go to Tools \ Interface \ Active Interface
Select your desired Interface then click okay
If you have more than one datasource, you will need to repeat these steps for each datasource.
