| Product(s): | ProjectWise Explorer Client | ||
| Version(s): | 08.11.11.559 | ||
| Area: | MISC | ||
| Original Author: | Bill Kenney, Bentley Technical Support Group |
User wants an environment attribute to have leading zeroes.
Product: ProjectWise Administrator V8i
Version: 08.11.11.111
Area: Environments, Problem ID#: 91128, Select Category
The attribute that needs to have leading zeroes (%03d) needed to be
defined as Varchar and not "Integer".
