| Product(s): | ProjectWise client | ||
| Version(s): | 8.11.11.111 | ||
| Area: | Explorer | ||
PDFs for Photo Preview are not showing when selecting that tab in ProjectWise Explorer after highlighting the PDF in ProjectWise Explorer document list box.
Check the mime type via right click > document.pdf > Properties >Advanced button > Mime type - you should see "Application/pdf" If not, then the mime type needs to be set, perhaps via dmsconvert
