| Product(s): | ProjectWise Client V8i | ||
| Version(s): | 08.11.07.443 | ||
| Area: | Workspace | ||
While trying to open an Architectural file in ProjectWise with Managed Workspace configured user receives error below.
Last Error [347]
Cannot start application for the specified document. Check your program associations. Failed to generate managed workspace configuration file invalid parameter passed to the API functiou.
Check user file association, it was set to a random path. Since user had Global association already set to the appropriate path, un-associating the user association resolved the issue.
Bentley's Technical Support Group requests that you please confine any comments you have on this Wiki entry to this " Comments or Corrections?" section. THANK YOU!
