| Product(s): | ProjectWise Explorer Client | ||
| Version(s): | 08.11.07.XX | ||
Opening a MicroStation file from ProjectWise, the managed workspace copies out correctly. If opening MicroStation from the desktop and then open a file (integrated with PW), it uses the local workspace
In the mcm.cfg, the variable, _MCM_WORKSPACE_LOCK was enabled, which does not allow MCM to change the workspace. disabling that variable resolved the problem
Bentley's Technical Support Group requests that you please confine any comments you have on this Wiki entry to this " Comments or Corrections?" section. THANK YOU!
